Disables the bundling of RSVP-TE messages for the specified VLAN interface.
| vlan | Specifies that message-bundling is to be disabled on a specific VLAN. |
| vlan_name | Identifies the VLAN interface on which message bundling is disabled. |
| vlan all | Specifies that message bundling is disabled on all VLAN interfaces that have been added to MPLS. |
Disabled.
This command disables the bundling of RSVP-TE messages for the VLAN specified interface. By default, message bundling is disabled. Specifying the all keyword disables message bundling on all VLANs that have been added to MPLS.
The following command disables message bundling on the specified VLAN:
disable mpls rsvp-te bundle-message vlan vlan_1
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
